跳转到主内容
Hamilton Beach 51101BA Rotor Replacement
你所需要的
  1. Hamilton Beach 51101BA Rotor Replacement, Rotor: 步骤 1 中的图像 1,3 Hamilton Beach 51101BA Rotor Replacement, Rotor: 步骤 1 中的图像 2,3 Hamilton Beach 51101BA Rotor Replacement, Rotor: 步骤 1 中的图像 3,3
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Rotor Replacement: 步骤 2 中的图像 1,1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Rotor Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Rotor Replacement: 步骤 4 中的图像 1,1
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Rotor Replacement: 步骤 5 中的图像 1,2 Hamilton Beach 51101BA Rotor Replacement: 步骤 5 中的图像 2,2
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Rotor Replacement: 步骤 6 中的图像 1,1
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
结论
另外一个人完成了本指南。
Andrew Huff
于09/04/15注册
568 声望
创作了3篇指南
团队
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G5
4 名成员
创作了5篇指南
一条评论
Hi, Any idea where to get a new rotor.
Allen Reed - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 1,294
