跳转到主内容
Hamilton Beach 51101BA Power Button Replacement
你所需要的
  1. Hamilton Beach 51101BA Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Hamilton Beach 51101BA Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Hamilton Beach 51101BA Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Remove the container from the base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Button Replacement: 步骤 2 中的图像 1,1
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Button Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Power Button Replacement: 步骤 4 中的图像 1,2 Hamilton Beach 51101BA Power Button Replacement: 步骤 4 中的图像 2,2
    • Unhinge the motor platform from the blender.
    • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
    • You do not need to completely remove this piece from the base.
  5. Hamilton Beach 51101BA Power Button Replacement: 步骤 5 中的图像 1,1
    • Pull out the rectangular green piece.
    • This is the actual power button.
  6. Hamilton Beach 51101BA Power Button Replacement: 步骤 6 中的图像 1,1
    • Some experience in soldering is required!
    • On the back of the power button, desolder the red and grey wires that are connected to the piece.
结论
2等其他人完成本指南。
Brandon Nunez
于08/28/15注册
283 声望
创作了2篇指南
团队
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 43
总计 3,289
