简介
After using this guide you will have learned how to replace the motor to your blender. You will need to use basic tools and soldering to complete this guide.
你所需要的
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Using a spudger, carefully insert the tip into the coil of wire around motor.
Move the motor platform to the side.
Lift up the motor and remove it from the blender.
2条评论
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Que tipo de motor tengo que comprar?
