跳转到主内容
简介
After using this guide you will have learned how to replace the motor to your blender. You will need to use basic tools and soldering to complete this guide.
  1. Remove the container from the blender. Hold the blender and the container, then twist the container in a clockwise motion. Make sure to follow the lock and unlock markings on the container.
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Turn the blender so the bottom is facing you.
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Unhinge the plastic motor platform from the blender.
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Using a spudger, carefully insert the tip into the coil of wire around motor. This is used to hold the rotating piece of the motor still.
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Remove the white rotor piece by rotating it counter-clockwise.
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Move the motor platform to the side. Lift up the motor and remove it from the blender.
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Some soldering experience required!
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Cut the thin black wire from the wire cap.
    • Cut the thin black wire from the wire cap.
结论
Andrew Huff
于2015年09月04日注册
487 信誉积分
创作了3篇指南
团队
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G5
4 名成员
创作了5篇指南
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - 回复
Que tipo de motor tengo que comprar?
hugoalex521 - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 12
过去的30天: 60
总计 4,706
