跳转到主内容
Hamilton Beach 49980A Large Heating Component Replacement
你所需要的
  1. Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: 步骤 1 中的图像 1,3 Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: 步骤 1 中的图像 2,3 Hamilton Beach 49980A Large Heating Component Replacement, Bottom Plate: 步骤 1 中的图像 3,3
    • Begin by inverting the coffee maker and resting it on a flat surface to make working on the bottom easier.
    • Now use a Y0 bit to remove all of the .46 inch long screws from the bottom.
    • Lift the plate to remove it from the rest of the machine.
  2. Hamilton Beach 49980A Large Heating Component Replacement, Motherboard: 步骤 2 中的图像 1,1
    • Once the bottom plate is removed, use a PH1 bit to remove the .525 inch long screws holding the motherboard bracket in the main housing.
  3. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 3 中的图像 1,2 Hamilton Beach 49980A Large Heating Component Replacement: 步骤 3 中的图像 2,2
    • Using a PH1 bit, remove the two .425 inch long screws holding down the white power cord bracket. This will give you the slack in the wire that you need to work on the motherboard.
    • Carefully remove the large white connector that has multiple wires attached to it. This is the wire connected to the button functions on the interface of the coffee maker.
  4. Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: 步骤 4 中的图像 1,3 Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: 步骤 4 中的图像 2,3 Hamilton Beach 49980A Large Heating Component Replacement, Large Heating Component: 步骤 4 中的图像 3,3
    • Remove the two .374 inch long Philips head screws from the brace using a PH1 bit and take the brace off.
  5. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 5 中的图像 1,1
    • Remove the second brace.
  6. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 6 中的图像 1,1
    • To remove the tubes from the large heating component, squeeze the spring clamps and slide them further down the tube.
    • Using pliers makes moving the spring clamps much easier, but it can be done by hand.
  7. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 7 中的图像 1,3 Hamilton Beach 49980A Large Heating Component Replacement: 步骤 7 中的图像 2,3 Hamilton Beach 49980A Large Heating Component Replacement: 步骤 7 中的图像 3,3
    • With the spring clamps moved down, slide the tubes from the ends of the large heating component. Once the ends are free, separate the component from the hot plate.
  8. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 8 中的图像 1,1
    • In order to remove the small housing that covers the motherboard, remove the lone screw with a PH1 bit.
  9. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 9 中的图像 1,2 Hamilton Beach 49980A Large Heating Component Replacement: 步骤 9 中的图像 2,2
    • Solder the brown wire connecting the large heating component to the motherboard and remove it.
    • The wire and all following wires will be hot, so use pliers to safely handle them.
  10. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 10 中的图像 1,2 Hamilton Beach 49980A Large Heating Component Replacement: 步骤 10 中的图像 2,2
    • Solder the white wire connecting the large heating component to the motherboard and remove it.
    • The wire will be hot, be sure to use pliers
  11. Hamilton Beach 49980A Large Heating Component Replacement: 步骤 11 中的图像 1,1
    • Gently remove the red wire connecting the large heating component to the motherboard using pliers. If this connection is too tight to remove by hand, you may heat the solder on the bottom and remove it completely.
    • When replacing any soldered components, you may want to apply new solder.
结论
Brandon Haghighi
于03/25/16注册
209 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-7, Miles Spring 2016 UMass Dartmouth, Team 1-7, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,220
