跳转到主内容
Hamilton Beach 48464 Tubing Replacement
你所需要的
  1. Hamilton Beach 48464 Tubing Replacement, Filter Basket: 步骤 1 中的图像 1,2 Hamilton Beach 48464 Tubing Replacement, Filter Basket: 步骤 1 中的图像 2,2
    • Carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Tubing Replacement: 步骤 2 中的图像 1,1
    • Slide out the filter basket that is sitting on top after opening the lid.
  3. Hamilton Beach 48464 Tubing Replacement, Tubing: 步骤 3 中的图像 1,2 Hamilton Beach 48464 Tubing Replacement, Tubing: 步骤 3 中的图像 2,2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
    • Once screws are removed, pull off the little circle piece.
  4. Hamilton Beach 48464 Tubing Replacement: 步骤 4 中的图像 1,2 Hamilton Beach 48464 Tubing Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
  5. Hamilton Beach 48464 Tubing Replacement: 步骤 5 中的图像 1,2 Hamilton Beach 48464 Tubing Replacement: 步骤 5 中的图像 2,2
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Once screws are removed, gently pull off the liner that is on the inside of the lid.
  6. Hamilton Beach 48464 Tubing Replacement: 步骤 6 中的图像 1,2 Hamilton Beach 48464 Tubing Replacement: 步骤 6 中的图像 2,2
    • After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
结论
Michael Damico
于02/10/16注册
661 声望
创作了6篇指南
团队
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 的会员
USFT-LACY-S16S14G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 779
