跳转到主内容
Hamilton Beach 48464 Power Cord Replacement
你所需要的
  1. Hamilton Beach 48464 Power Cord Replacement, Base: 步骤 1 中的图像 1,1
    • This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
  2. Hamilton Beach 48464 Power Cord Replacement: 步骤 2 中的图像 1,3 Hamilton Beach 48464 Power Cord Replacement: 步骤 2 中的图像 2,3 Hamilton Beach 48464 Power Cord Replacement: 步骤 2 中的图像 3,3
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
  3. Hamilton Beach 48464 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
  4. Hamilton Beach 48464 Power Cord Replacement: 步骤 4 中的图像 1,1
    • Gently lift the base away from the Brew Station.
  5. Hamilton Beach 48464 Power Cord Replacement, Power Cord: 步骤 5 中的图像 1,2 Hamilton Beach 48464 Power Cord Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
  6. Hamilton Beach 48464 Power Cord Replacement: 步骤 6 中的图像 1,1
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline. This will release the bracket that is holding down the large piece in the middle.
  7. Hamilton Beach 48464 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Using one hand, gently lift the large silver piece out of the base.
    • The silver piece will still be connected to the Brew Station, so handy it with care.
  8. Hamilton Beach 48464 Power Cord Replacement: 步骤 8 中的图像 1,1
    • Once the screw is out, gently lift the white circuit board out of the base. This will be where the power cord begins, so you will now have access to the full length of the cord.
结论
另外一个人完成了本指南。
Michael Damico
于02/10/16注册
661 声望
创作了6篇指南
团队
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 的会员
USFT-LACY-S16S14G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 9
总计 244
