跳转到主内容
Hamilton Beach 48464 Heating Plate Replacement
你所需要的
  1. Hamilton Beach 48464 Heating Plate Replacement, Heating Plate: 步骤 1 中的图像 1,1
    • To begin, carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Heating Plate Replacement: 步骤 2 中的图像 1,1
    • Gently pull out the filter basket from the Brew Station and set it to the side.
  3. Hamilton Beach 48464 Heating Plate Replacement: 步骤 3 中的图像 1,1
    • Grab the handle and pull up to remove the top container.
    • Set this piece close by as you will be needing it for a future step.
  4. Hamilton Beach 48464 Heating Plate Replacement: 步骤 4 中的图像 1,2 Hamilton Beach 48464 Heating Plate Replacement: 步骤 4 中的图像 2,2
    • Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
  5. Hamilton Beach 48464 Heating Plate Replacement: 步骤 5 中的图像 1,2 Hamilton Beach 48464 Heating Plate Replacement: 步骤 5 中的图像 2,2
    • Check again to make sure that the coffee maker is not plugged in.
    • Once the screws are removed, carefully pull off the metal piece.
    • Once the piece is removed, you will be able to access the heater.
  6. Hamilton Beach 48464 Heating Plate Replacement: 步骤 6 中的图像 1,2 Hamilton Beach 48464 Heating Plate Replacement: 步骤 6 中的图像 2,2
    • This step involves using the top contained that you put aside in step 3.
    • Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
  7. Hamilton Beach 48464 Heating Plate Replacement: 步骤 7 中的图像 1,1
    • Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
    • There are rubber washers inside each of the 8 holes on the piece of metal. Be careful to not let any fall out when handling the piece.
结论
另外一个人完成了本指南。
Michael Damico
于02/10/16注册
661 声望
创作了6篇指南
团队
USF Tampa, Team 14-1, Lacy Spring 2016 USF Tampa, Team 14-1, Lacy Spring 2016 的会员
USFT-LACY-S16S14G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 942
