简介
This guide will show you how to replace the Front Panel and gain access to the electronic circuit board and Power cord of the Brew Station. Be extra careful when unscrewing any screw and make sure the power is off.
你所需要的
Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
Using one hand, hold all cords away from the front end of the Brew Station.
Using your other hand, use the Philips 2 Screwdriver to unscrew the two 8-mm screws labeled in a red outline. They are located inside the base on the front end of the Brew Station.
Once the screws from the previous step are out, you will be able to grab the bottom half of the Brew Station and lift it up.
Use one hand to lift up the bottom half of the Brew Station and use your other hand to unscrew the two 8-mm screws labeled in a red outline with a Phillips 2 Screwdriver.
2等其他人完成本指南。
