简介
This is a straight-forward process that requires removal of a few screws and two wire caps.
你所需要的
Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
即将完成!
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
结论
2等其他人完成本指南。
