跳转到主内容
Hamilton Beach 25460Z Plug Wiring Replacement
你所需要的
  1. Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: 步骤 1 中的图像 1,2 Hamilton Beach 25460Z Plug Wiring Replacement, Plug Wiring: 步骤 1 中的图像 2,2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 2 中的图像 1,1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 3 中的图像 1,3 Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 3 中的图像 2,3 Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 3 中的图像 3,3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 4 中的图像 1,2 Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 4 中的图像 2,2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 5 中的图像 1,2 Hamilton Beach 25460Z Plug Wiring Replacement: 步骤 5 中的图像 2,2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
结论
To reassemble your device, follow these instructions in reverse order. Make sure to correctly replace the wires using tape you placed earlier as a reference.
2等其他人完成本指南。
Maxwell Taylor
于02/08/15注册
149 声望
撰写一个指南
团队
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G27
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 665
