跳转到主内容
Hamilton Beach 25460Z Handle Replacement
你所需要的
  1. Hamilton Beach 25460Z Handle Replacement, Handle: 步骤 1 中的图像 1,2 Hamilton Beach 25460Z Handle Replacement, Handle: 步骤 1 中的图像 2,2
    • Unplug your device before proceeding with disassembly.
    • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
    • Repeat for the other washer across from the first one.
  2. Hamilton Beach 25460Z Handle Replacement: 步骤 2 中的图像 1,2 Hamilton Beach 25460Z Handle Replacement: 步骤 2 中的图像 2,2
    • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
    • Pull the end of the bolt out to completely remove it.
    • Repeat for the second bolt.
  3. Hamilton Beach 25460Z Handle Replacement: 步骤 3 中的图像 1,2 Hamilton Beach 25460Z Handle Replacement: 步骤 3 中的图像 2,2
    • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
  4. Hamilton Beach 25460Z Handle Replacement: 步骤 4 中的图像 1,1
    • Unscrew the locking knob all the way to remove it.
  5. Hamilton Beach 25460Z Handle Replacement: 步骤 5 中的图像 1,3 Hamilton Beach 25460Z Handle Replacement: 步骤 5 中的图像 2,3 Hamilton Beach 25460Z Handle Replacement: 步骤 5 中的图像 3,3
    • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
结论
团队
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G27
4 名成员
创作了6篇指南
2条评论
And where do I buy the handle?? I can’t find it anywhere
if someone see this, please help me!
Tulio
Tulioalejandro@icloud.com
tulio181 - 回复
I too am looking for a replacement handle! They get brittle from the heat...mine just snapped on the left side..
salikah11@yahoo.ca
DEE EFF - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 1,605
