跳转到主内容
Hamilton Beach 25460Z Bottom Heating Element Solders Replacement
你所需要的
  1. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: 步骤 1 中的图像 1,2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Plug Wiring: 步骤 1 中的图像 2,2
    • Unplug your device before proceeding with disassembly.
    • Remove the four 14mm screws from the bottom of the Panini Press using the T10 Screwdriver.
  2. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 2 中的图像 1,1
    • Lift up the plastic cover to expose the plug wiring.
    • Mark the plug wire connected to the red wire with a piece of tape. This will be used as a reference for reassembly.
  3. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 3 中的图像 1,3 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 3 中的图像 2,3 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 3 中的图像 3,3
    • Use the pliers to pinch the widest point of the cap. This should be done opposite of the already existing crimps.
    • Slide off the white cap.
    • Repeat these steps for the second white cap.
  4. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 4 中的图像 1,2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 4 中的图像 2,2
    • Remove the two rubber screw covers from the bottom of the Panini Press.
    • Remove the four uncovered 10mm screws with the PH2 Screwdriver.
  5. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 5 中的图像 1,2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 5 中的图像 2,2
    • Lift the plastic lower heating element up and place to the side for reassembly. You have now disconnected the plug wiring completely.
  6. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: 步骤 6 中的图像 1,2 Hamilton Beach 25460Z Bottom Heating Element Solders Replacement, Bottom Heating Element Solders: 步骤 6 中的图像 2,2
    • Using the PH2 screwdriver and a bit of force, remove the two 10mm screws holding the thermal switch to the cooking surface.
    • These screws may be difficult to remove.
  7. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 7 中的图像 1,1
    • Using the PH2 screwdriver, remove the single 10mm screw connecting the red wiring cover to the cooking surface.
  8. Hamilton Beach 25460Z Bottom Heating Element Solders Replacement: 步骤 8 中的图像 1,1
    • Now pull both the thermal switch and the red wire to the back of the press, allowing easier access to the heating element leads.
    • Replace the missing solder.
    • The left lead, marked with a red circle, is connected to 2 white wires.
    • The right lead, marked with a yellow circle, is connected to 2 red wires.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 6-27, Amido Winter 2015 Cal Poly, Team 6-27, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G27
4 名成员
创作了6篇指南
2条评论
Muy detallado, era aproximadamente lo que buscaba.
Hay posibilidades de que sea en los pasos a seguir, sean en Español. De ser así podría resolver el problema, gracias
alcides torres lopez - 回复
Estoy tratando de resolver la avería de mo Sandwichera Hamilton Beach modelo 25460Z, desde mi hogar y desearía que la respuesta fuera en idioma Español, gracias
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 26
总计 2,949
