跳转到主内容
Hamilton Beach 22794 Disassembly
你所需要的
  1. Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: 步骤 1 中的图像 1,3 Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: 步骤 1 中的图像 2,3 Hamilton Beach 22794 Disassembly, Hamilton Beach 22794: 步骤 1 中的图像 3,3
    • Remove the crumb tray from the back of the toaster.
    • It may require a firm tug on the tray.
  2. Hamilton Beach 22794 Disassembly: 步骤 2 中的图像 1,3 Hamilton Beach 22794 Disassembly: 步骤 2 中的图像 2,3 Hamilton Beach 22794 Disassembly: 步骤 2 中的图像 3,3
    • Turn the toaster on it's side and unscrew all 6 Phillips #0 screws from the bottom housing.
    • The first 5 are all 12.5mm screws
    • The last screw is on the left side and measures 10 mm.
    • One of the screws is of a different color on the LEFT side.
  3. Hamilton Beach 22794 Disassembly: 步骤 3 中的图像 1,3 Hamilton Beach 22794 Disassembly: 步骤 3 中的图像 2,3 Hamilton Beach 22794 Disassembly: 步骤 3 中的图像 3,3
    • Remove the bottom housing of the toaster.
    • This may require a small plastic spudger if it's not easily coming apart.
  4. Hamilton Beach 22794 Disassembly: 步骤 4 中的图像 1,3 Hamilton Beach 22794 Disassembly: 步骤 4 中的图像 2,3 Hamilton Beach 22794 Disassembly: 步骤 4 中的图像 3,3
    • As you're removing the bottom, make sure to move any brackets out of the way and unclip the white cable.
    • Pull the cable firmly up & out to free it from the clips.
  5. Hamilton Beach 22794 Disassembly: 步骤 5 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 5 中的图像 2,2
    • Gently lay the bottom housing down and unscrew the 10 mm screws securing the small white bracket with a Phillips #0 screwdriver.
  6. Hamilton Beach 22794 Disassembly: 步骤 6 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 6 中的图像 2,2
    • Go to the front of the toaster to remove the large square handle.
    • This requires a firm tug and possibly a slight twist to free it from the metal rod.
  7. Hamilton Beach 22794 Disassembly: 步骤 7 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 7 中的图像 2,2
    • Now that the bottom housing and the handle are removed, you can pull up on the central unit and remove it from the top housing.
    • You may need to wiggle this unit to free it from any snagging/catching.
  8. Hamilton Beach 22794 Disassembly: 步骤 8 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 8 中的图像 2,2
    • After removal, you will see two small wires plugged in to a board.
    • Firmly pull up on these wires to unplug.
  9. Hamilton Beach 22794 Disassembly: 步骤 9 中的图像 1,3 Hamilton Beach 22794 Disassembly: 步骤 9 中的图像 2,3 Hamilton Beach 22794 Disassembly: 步骤 9 中的图像 3,3
    • Unscrew the two Phillips #0 7 mm screws that secure the metal backing to the circuit board.
    • Remove the metal backing.
    • Unscrew the two 5 mm Phillips #0 screws and remove the board.
  10. Hamilton Beach 22794 Disassembly: 步骤 10 中的图像 1,3 Hamilton Beach 22794 Disassembly: 步骤 10 中的图像 2,3 Hamilton Beach 22794 Disassembly: 步骤 10 中的图像 3,3
    • Using your metal spudger, unfold the metal bracket and unhook the spring so that you can free the press-down mechanism.
  11. Hamilton Beach 22794 Disassembly: 步骤 11 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 11 中的图像 2,2
    • Unhook the other springs on the size and pull up on the metal rod to free the push-down mechanism from the center part.
  12. Hamilton Beach 22794 Disassembly: 步骤 12 中的图像 1,2 Hamilton Beach 22794 Disassembly: 步骤 12 中的图像 2,2
    • Using your metal spudger, unfold the metal tabs holding the bread-holding trays in place.
    • Pulling up, remove the bread-holding metal trays.
  13. Hamilton Beach 22794 Disassembly: 步骤 13 中的图像 1,1
    • Now that we know how to dissaseble the toaster, it's valuable to learn a little bit about how it functions:
    • The toaster constantly receives power when it's plugged in, but the electrical circuit remains inactive until you push down the handle.
    • Pushing down the handle causes two switches to close, completing the circuit and activating the toaster's power source.
    • The circuit breaks when a certain power level is reached in the timing chip on the circuit board. This signal weakens the electromagnet, releasing the handle and popping up the bread trays.
    • A potentiometer, linked to the control knob on the front of the device, regulates power flow to the chip.
    • Setting to maximum (level seven) restricts the power flow, prolonging toasting. On the other hand, choosing cancel reduces resistance, quickly ejecting the toast.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 74
总计 350
