跳转到主内容
Hair Scrunchie Elastic Replacement
你所需要的
  1. Hair Scrunchie Elastic Replacement, Hair Scrunchie Elastic: 步骤 1 中的图像 1,1
    • There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
  2. Hair Scrunchie Elastic Replacement: 步骤 2 中的图像 1,2 Hair Scrunchie Elastic Replacement: 步骤 2 中的图像 2,2
    • Locate the short seam and use the hem ripper to carefully cut through each stitch without damaging the fabric.
    • Do not cut through the stitches where the long seam intersect with he short seam.
  3. Hair Scrunchie Elastic Replacement: 步骤 3 中的图像 1,1
    • Attach the elastic band to the end of a pencil with a piece of tape.
  4. Hair Scrunchie Elastic Replacement: 步骤 4 中的图像 1,2 Hair Scrunchie Elastic Replacement: 步骤 4 中的图像 2,2
    • Insert the pencil tip into one end of the fabric tube.
    • As you push the pencil through, scrunch the fabric together until the tip comes out the other side.
  5. Hair Scrunchie Elastic Replacement: 步骤 5 中的图像 1,2 Hair Scrunchie Elastic Replacement: 步骤 5 中的图像 2,2
    • Tie a secure knot with the newly replaced elastic.
  6. Hair Scrunchie Elastic Replacement: 步骤 6 中的图像 1,1
    • Prepare your needle and thread by tying a knot at the end.
  7. Hair Scrunchie Elastic Replacement: 步骤 7 中的图像 1,1
    • Insert the needle at the spot holding each end of the tube together.
  8. Hair Scrunchie Elastic Replacement: 步骤 8 中的图像 1,3 Hair Scrunchie Elastic Replacement: 步骤 8 中的图像 2,3 Hair Scrunchie Elastic Replacement: 步骤 8 中的图像 3,3
    • Use the ladder stitch technique to sew each end of the tube back together.
    • Use this guide for assistance.
  9. Hair Scrunchie Elastic Replacement: 步骤 9 中的图像 1,3 Hair Scrunchie Elastic Replacement: 步骤 9 中的图像 2,3 Hair Scrunchie Elastic Replacement: 步骤 9 中的图像 3,3
    • Tie a knot and use your finger to keep the knot close as close to the fabric as possible.
    • Repeat this process until the thread is secure.
  10. Hair Scrunchie Elastic Replacement: 步骤 10 中的图像 1,1
    • Trim the thread as close to the knot as possible.
结论
This is a simple and effective way to replace the elastic so that you can continue to use the hair accessory.
9等其他人完成本指南。
Malena Hansen
于10/24/18注册
239 声望
撰写一个指南
团队
UC Davis, Team S2-G2, Bender Fall 2018 UC Davis, Team S2-G2, Bender Fall 2018 的会员
UCD-BENDER-F18S2G2
3 名成员
创作了2篇指南
一条评论
Amazing
Been looking for a way to fix my scrunchie
Thanks!
Mollytheduck1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 34
过去 30 天: 104
总计 23,457
