跳转到主内容
Hair Dryer Button Switchboard Replacement
你所需要的
  1. Hair Dryer Button Switchboard Replacement, Nozzle: 步骤 1 中的图像 1,2 Hair Dryer Button Switchboard Replacement, Nozzle: 步骤 1 中的图像 2,2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Button Switchboard Replacement, Grating: 步骤 2 中的图像 1,1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Button Switchboard Replacement: 步骤 3 中的图像 1,1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Button Switchboard Replacement: 步骤 4 中的图像 1,1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Button Switchboard Replacement, Button Switchboard: 步骤 5 中的图像 1,1
    • Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
  6. Hair Dryer Button Switchboard Replacement: 步骤 6 中的图像 1,1
  7. Hair Dryer Button Switchboard Replacement: 步骤 7 中的图像 1,1
    • The hairdryer is now disassembled. The fan, motor, heating element cover, and internal wiring are exposed.
    • Please be careful around these parts of the hairdryer. Even if the device is off, they may be warm to the touch.
    • This is the TURBO button.
    • This is the SWITCHBOARD button.
  8. Hair Dryer Button Switchboard Replacement: 步骤 8 中的图像 1,1
    • Gently pull the turbo button away from the hair dryer body.
    • If the turbo setting is still not working after you replace the switchboard, consider using soldering techniques to replace the turbo button. It may be why the hairdryer is not working properly, too.
  9. Hair Dryer Button Switchboard Replacement: 步骤 9 中的图像 1,1
    • Gently pull the button switchboard away from the hair dryer body.
    • Using a desoldering wick and a soldering iron, desolder the wires. This will help with the electrical connection issues that may be occurring.
    • Refer to the following page for desoldering instructions: Soldering Skills
结论
另外一个人完成了本指南。
Mitch
于10/04/12注册
34 声望
创作了5篇指南
团队
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G29
5 名成员
创作了6篇指南
一条评论
I have a hairdryer with loose wire. Can you help me to find where the wire should be welded?
ziad musa - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 64
总计 8,313
