简介
This guide demonstrates how to quickly and safely check, and, if necessary, replace the run capacitor in your residential HVAC condenser unit. This process can also be used, with some modification, to check other capacitors, such as the blower motor capacitor in the furnace of your HVAC system.
When following this guide please remember safety first: remember to turn the power off before you start and turn it back on only when you have everything reassembled.
你所需要的
Use the capacitor discharge tool to bridge the gap between the terminals labeled "Hum" (Compressor) and "common" (ground). This will discharge any stored electricity in the capacitance meter to prevent any damage to you and your capacitor meter.
Repeat the process with the "fan" terminal and the "common" terminal.
2等其他人完成本指南。
