跳转到主内容
HUAWEI HONOR 5X Front And Back Camera Replacement
你所需要的
  1. HUAWEI HONOR 5X Front And Back Camera Replacement, HUAWEI HONOR 5X Disassembly: 步骤 1 中的图像 1,1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 3 中的图像 1,2 HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 3 中的图像 2,2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 4 中的图像 1,1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 5 中的图像 1,2 HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 5 中的图像 2,2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: 步骤 6 中的图像 1,2 HUAWEI HONOR 5X Front And Back Camera Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 7 中的图像 1,2 HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 8 中的图像 1,3 HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 8 中的图像 2,3 HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 8 中的图像 3,3
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Front And Back Camera Replacement, Front And Back Camera: 步骤 9 中的图像 1,1
    • Use a plastic opening tool to pry up and disconnect the camera from the motherboard.
  10. HUAWEI HONOR 5X Front And Back Camera Replacement: 步骤 10 中的图像 1,1
    • Use a plastic opening tool to pry the front camera connector from its socket on the motherboard.
结论
Klara Asllani
于01/25/18注册
788 声望
创作了5篇指南
团队
USF Tampa, Team S7-G6, Passmore Spring 2018 USF Tampa, Team S7-G6, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 347
