跳转到主内容
HTC myTouch 3G Glass Screen/LED Display Replacement
你所需要的
  1. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove the Cover: 步骤 1 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove the Cover: 步骤 1 中的图像 2,2
    • Press both thumbs on each side of the upper corners, and apply pressure in a downward motion.
    • While applying downward pressure, slide the back cover down and off the phone.
  2. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Battery and SIM Card: 步骤 2 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Battery and SIM Card: 步骤 2 中的图像 2,2
    • Remove the battery.
    • Remove the SIM card.
  3. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove SD Card: 步骤 3 中的图像 1,1
    • Push the SD card in to eject it.
    • Pull the SD card out.
  4. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Panel Screws: 步骤 4 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Panel Screws: 步骤 4 中的图像 2,2
    • Remove the four 6 mm T5 Torx screws from the four corners on the back of the phone.
    • Remove the two 4 mm T5 Torx screws from the middle of the back of the phone.
  5. HTC myTouch 3G Glass Screen/LED Display Replacement, Access the Motherboard: 步骤 5 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Access the Motherboard: 步骤 5 中的图像 2,2
    • Pull out the antenna cover to access the motherboard.
  6. HTC myTouch 3G Glass Screen/LED Display Replacement, Dislodge the Back Plate: 步骤 6 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Dislodge the Back Plate: 步骤 6 中的图像 2,2
    • Insert a spudger into the gap between the frame and cover. Push downward with the spudger to separate the back plate from the phone.
    • With the spudger in the gap between the frame and cover, move the spudger around the edge of the of the phone to finish removing the back plate.
  7. HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Screws: 步骤 7 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement, Remove Back Screws: 步骤 7 中的图像 2,2
    • Remove the 3 mm Phillips screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3 mm Phillips screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
  8. HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 步骤 8 中的图像 1,3 HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 步骤 8 中的图像 2,3 HTC myTouch 3G Glass Screen/LED Display Replacement, Separate the Circuit Board: 步骤 8 中的图像 3,3
    • Place a finger between the circuit board and front cover, and lift the circuit board gently.
    • Separate the circuit board from the front cover and screen to access the ribbon cable holding them together. Detach the ribbon cable.
    • Finish separating the circuit board from the front panel.
  9. HTC myTouch 3G Glass Screen/LED Display Replacement, Glass Screen/LED Display: 步骤 9 中的图像 1,1
    • After following the prerequisite guide listed above, the phone should have the circuit board housing group on one piece.
    • The front cover and screen of the phone should be located on the other piece.
  10. HTC myTouch 3G Glass Screen/LED Display Replacement: 步骤 10 中的图像 1,2 HTC myTouch 3G Glass Screen/LED Display Replacement: 步骤 10 中的图像 2,2
    • Place a finger on the front side of the screen, and push up as indicated.
    • Carefully grab onto the sides of the LCD and glass screen.
    • Continue to angle the LCD and glass screen further up.
  11. HTC myTouch 3G Glass Screen/LED Display Replacement: 步骤 11 中的图像 1,1
    • Carefully lift the screen away from the front cover.
    • The adhesive should be easy to separate while separating the front cover from the screen.
  12. HTC myTouch 3G Glass Screen/LED Display Replacement: 步骤 12 中的图像 1,1
    • Change old LCD and glass digitizer with a replacement.
    • The LCD and glass digitizer can be separated by disconnecting the ribbon cable, and separating the layer of the LCD from the glass screen.
结论
Tony Tran
于09/25/12注册
381 声望
创作了3篇指南
团队
Cal Poly, Team 2-9, Propen Fall 2012 Cal Poly, Team 2-9, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G9
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,854
