本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will explain how to install / remove the receiver on the HTC Wizard 200.
你所需要的
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
即将完成!
结论
