本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will display how to remove and install the back panel of the HTC Wizard 200.
你所需要的
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
在这个步骤中使用的工具:T5 Torx Screwdriver$5.49
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
即将完成!
结论
