跳转到主内容
HTC Wizard 100 Speakers Replacement
你所需要的
  1. HTC Wizard 100 Speakers Replacement, Battery: 步骤 1 中的图像 1,2 HTC Wizard 100 Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Speakers Replacement: 步骤 2 中的图像 1,2 HTC Wizard 100 Speakers Replacement: 步骤 2 中的图像 2,2
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Speakers Replacement, Back Case: 步骤 3 中的图像 1,2 HTC Wizard 100 Speakers Replacement, Back Case: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Speakers Replacement: 步骤 4 中的图像 1,1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Speakers Replacement: 步骤 5 中的图像 1,3 HTC Wizard 100 Speakers Replacement: 步骤 5 中的图像 2,3 HTC Wizard 100 Speakers Replacement: 步骤 5 中的图像 3,3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Speakers Replacement, Speakers: 步骤 6 中的图像 1,2 HTC Wizard 100 Speakers Replacement, Speakers: 步骤 6 中的图像 2,2
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
结论
Taylor Stone
于10/06/11注册
45 声望
创作了2篇指南
团队
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G28
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 578
