Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
