跳转到主内容
加入维修社区 - 创建账户
HTC Wizard 100 Motherboard Replacement
你所需要的
    1. HTC Wizard 100 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 HTC Wizard 100 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      询问修复机器人
      添加评论
    2. HTC Wizard 100 Motherboard Replacement: 步骤 2 中的图像 1,2 HTC Wizard 100 Motherboard Replacement: 步骤 2 中的图像 2,2
      • Pull on the plastic tab to release the battery.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Motherboard Replacement, Back Case: 步骤 3 中的图像 1,2 HTC Wizard 100 Motherboard Replacement, Back Case: 步骤 3 中的图像 2,2
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      询问修复机器人
      添加评论
    2. HTC Wizard 100 Motherboard Replacement: 步骤 4 中的图像 1,1
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      询问修复机器人
      添加评论
    3. HTC Wizard 100 Motherboard Replacement: 步骤 5 中的图像 1,3 HTC Wizard 100 Motherboard Replacement: 步骤 5 中的图像 2,3 HTC Wizard 100 Motherboard Replacement: 步骤 5 中的图像 3,3
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Motherboard Replacement, Speakers: 步骤 6 中的图像 1,2 HTC Wizard 100 Motherboard Replacement, Speakers: 步骤 6 中的图像 2,2
      • Grip the speaker connector with your thumb and finger and gently pull up.
      • Repeat for 2nd speaker.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Motherboard Replacement, Camera: 步骤 7 中的图像 1,1
      • Locate the camera and pry off with the plastic opening tool or spudger.
      询问修复机器人
      添加评论
    1. HTC Wizard 100 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
      • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
      询问修复机器人
      添加评论
    2. HTC Wizard 100 Motherboard Replacement: 步骤 9 中的图像 1,2 HTC Wizard 100 Motherboard Replacement: 步骤 9 中的图像 2,2
      • Remove the plastic tape to reveal the connector.
      • Use your finger or plastic opening tool to flip the connector and release the cable.
      询问修复机器人
      添加评论
    3. HTC Wizard 100 Motherboard Replacement: 步骤 10 中的图像 1,2 HTC Wizard 100 Motherboard Replacement: 步骤 10 中的图像 2,2
      • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
      • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
      • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Eric W
于09/22/11注册
41 声望
创作了3篇指南
团队
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G28
4 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 1,156
