跳转到主内容
HTC Windows Phone 8S Logic Board Replacement
你所需要的
视频概述
  1. HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: 步骤 1 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: 步骤 1 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement, Loudspeaker: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Logic Board Replacement: 步骤 2 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement: 步骤 2 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement: 步骤 2 中的图像 3,3
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Logic Board Replacement, Battery: 步骤 3 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement, Battery: 步骤 3 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Logic Board Replacement: 步骤 4 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement: 步骤 4 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement: 步骤 4 中的图像 3,3
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Logic Board Replacement, Flex Cables: 步骤 5 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: 步骤 5 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement, Flex Cables: 步骤 5 中的图像 3,3
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: 步骤 6 中的图像 1,3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: 步骤 6 中的图像 2,3 HTC Windows Phone 8S Logic Board Replacement, Logic Board Removal: 步骤 6 中的图像 3,3
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: 步骤 7 中的图像 1,2 HTC Windows Phone 8S Logic Board Replacement, Logic Board / Main Board: 步骤 7 中的图像 2,2
    • HTC Windows Phone 8S Logic Board.
结论
另外一个人完成了本指南。
ZFix
于12/09/13注册
195,865 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,451篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,149
