跳转到主内容
HTC Vive Head Strap Replacement
你所需要的
  1. HTC Vive Head Strap Replacement, Release the upper head strap: 步骤 1 中的图像 1,2 HTC Vive Head Strap Replacement, Release the upper head strap: 步骤 1 中的图像 2,2
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. HTC Vive Head Strap Replacement, Remove the upper head strap: 步骤 2 中的图像 1,2 HTC Vive Head Strap Replacement, Remove the upper head strap: 步骤 2 中的图像 2,2
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. HTC Vive Head Strap Replacement, Remove the right side of the head strap: 步骤 3 中的图像 1,3 HTC Vive Head Strap Replacement, Remove the right side of the head strap: 步骤 3 中的图像 2,3 HTC Vive Head Strap Replacement, Remove the right side of the head strap: 步骤 3 中的图像 3,3
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
  4. HTC Vive Head Strap Replacement, Remove the left side of the head strap: 步骤 4 中的图像 1,3 HTC Vive Head Strap Replacement, Remove the left side of the head strap: 步骤 4 中的图像 2,3 HTC Vive Head Strap Replacement, Remove the left side of the head strap: 步骤 4 中的图像 3,3
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
  5. HTC Vive Head Strap Replacement, Remove the head strap: 步骤 5 中的图像 1,3 HTC Vive Head Strap Replacement, Remove the head strap: 步骤 5 中的图像 2,3 HTC Vive Head Strap Replacement, Remove the head strap: 步骤 5 中的图像 3,3
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
结论
6等其他人完成本指南。
Adam O'Camb
于04/11/15注册
196,940 声望
创作了416篇指南
3条评论
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - 回复
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell -
how to fix my headset strap on my vive i nead some help on it can you show me how.
GreggTHhompson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 72
总计 6,010
