跳转到主内容
HTC Vive Cosmos Lens and LCD Frame Replacement
你所需要的
  1. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: 步骤 1 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: 步骤 1 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the facerest: 步骤 1 中的图像 3,3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: 步骤 2 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Release the faceplate switch: 步骤 2 中的图像 2,2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  3. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: 步骤 3 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the faceplate: 步骤 3 中的图像 2,2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  4. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the focus knob: 步骤 4 中的图像 1,1
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
  5. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: 步骤 5 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus knob: 步骤 5 中的图像 2,2
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
  6. HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: 步骤 6 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: 步骤 6 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Unplug the audio connector: 步骤 6 中的图像 3,3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  7. HTC Vive Cosmos Lens and LCD Frame Replacement, Unscrew the LCD and motherboard assembly: 步骤 7 中的图像 1,1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
  8. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 8 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 8 中的图像 2,2
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
  9. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 9 中的图像 1,1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
  10. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the microphone: 步骤 10 中的图像 1,1
    • Remove the microphone cover from the bottom edge of the headset.
  11. HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: 步骤 11 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Separate the microphone adhesive: 步骤 11 中的图像 2,2
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
  12. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: 步骤 12 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: 步骤 12 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the upper component cover: 步骤 12 中的图像 3,3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
  13. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: 步骤 13 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: 步骤 13 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the camera connector covers: 步骤 13 中的图像 3,3
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
  14. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: 步骤 14 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: 步骤 14 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the cameras: 步骤 14 中的图像 3,3
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
  15. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 15 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 15 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 15 中的图像 3,3
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
  16. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 16 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 16 中的图像 2,2
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
  17. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the microphone: 步骤 17 中的图像 1,1
    • Peel the yellow tape off of the microphone connector.
  18. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 18 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 18 中的图像 2,2
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
  19. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 19 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 19 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 19 中的图像 3,3
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
  20. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: 步骤 20 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD and motherboard assembly: 步骤 20 中的图像 2,2
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
  21. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panels: 步骤 21 中的图像 1,1
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
  22. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 22 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 22 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 22 中的图像 3,3
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
  23. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: 步骤 23 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: 步骤 23 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD frame assembly: 步骤 23 中的图像 3,3
    • Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
  24. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 24 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 24 中的图像 2,2
    • Remove the LCD frame assembly from the midframe.
    • During reassembly, first seat the support rod in its slots in the midframe. Then gently press the rest of the LCD frame assembly into the midframe so that the bottom edges of the LCD frames clip into the midframe.
  25. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: 步骤 25 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: 步骤 25 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens gasket: 步骤 25 中的图像 3,3
    • Gently lift the lens gasket off of the lens and LCD frames to remove it.
  26. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: 步骤 26 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the support rod: 步骤 26 中的图像 2,2
    • Slide the support rod out of its brackets on the lens and LCD frames.
  27. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the focus rod: 步骤 27 中的图像 1,1
    • Use a T5 Torx driver to remove the four 4.1 mm screws securing the focus rod brackets.
  28. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 28 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 28 中的图像 2,2
    • Remove the focus rod and its brackets.
  29. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: 步骤 29 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: 步骤 29 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the outer LCD cover: 步骤 29 中的图像 3,3
    • Pick one lens and LCD frame to work with for the rest of the guide. After removing the first frame, repeat the next seven steps with the other frame to remove it as well.
    • Insert the flat end of a spudger in between the edge of the lens LCD frame and the outer LCD cover.
    • Twist the spudger to release the clips securing the LCD cover to the frame.
    • Repeat the insertion and twisting process for each clip on the LCD cover.
  30. HTC Vive Cosmos Lens and LCD Frame Replacement, Disconnect the LCD panel: 步骤 30 中的图像 1,1
    • Gently peel the sticker covering the LCD cable and connector back far enough to access the LCD connector.
  31. HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 31 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 31 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement: 步骤 31 中的图像 3,3
    • Use the flat end of a spudger to flip up the locking flap securing the LCD cable ZIF connector.
    • Carefully slide the LCD cable straight out of its socket.
  32. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: 步骤 32 中的图像 1,2 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the inner LCD cover: 步骤 32 中的图像 2,2
    • Slowly lift the LCD cover away from the lens and LCD frame, taking care to thread the LCD cable through the cover.
  33. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: 步骤 33 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: 步骤 33 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the LCD panel: 步骤 33 中的图像 3,3
    • This step may damage the LCD panel. Continue only if the panel is already damaged.
    • Use the flat end of a spudger to pry up the LCD panel.
    • Remove the LCD panel.
  34. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: 步骤 34 中的图像 1,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: 步骤 34 中的图像 2,3 HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens: 步骤 34 中的图像 3,3
    • Push against the back of the lens to remove it from the frame.
    • If this is difficult, try heating the lens to soften the adhesive holding it to the frame.
  35. HTC Vive Cosmos Lens and LCD Frame Replacement, Remove the lens and LCD frame: 步骤 35 中的图像 1,1
    • Only the lens and LCD frame remains.
    • Repeat the last seven steps with the other lens and LCD frame to remove it as well.
结论
Adam O'Camb
于04/11/15注册
217,479 声望
创作了416篇指南
3指南评论
Good guide, it's not too hard it's just really tedious and annoying, I think I managed to finish the repair within an hour. The main annoying part is the mic and reconnecting the ribbon cable.
Josh (BeigeAnimal) - 回复
Would this process work on the Cosmos Elite as well?
Wickednoreaster - 回复
Yes it would. As the the elite is the same HMD but with a different faceplate.
Synapse -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 1,635
