简介
The HTC Vive controller motherboard may be damaged and not able to function. The motherboard is crucial for all functions of the remote. This guide will show you how to replace the motherboard.
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
9等其他人完成本指南。
13条评论
Hi, do you know where I can get a new motherboard? I bought my controller second hand and after several months it stoppedworking…. when I took it apart the connection at the bottom has been removed and two wires soldered in place but it’s so small I can’t do it again so I need a new motherboard
thanks
I am looking for the connetor at step 10. The top of the connector is broken (fail quality assurence). I am not interrested to purchase a new controler at 200$ because of a 2 cents connector.
Thank you
I had the same connector problem in step 10, where can I just buy the mother board
did either of you find the connector for the power button to mother board in step 10
