简介
使用本指南移除或更换 HTC Vive 手柄的前面板。卸下前面板时,小心不要撕裂带状电缆或它们对应的任何接口。
你所需要的
使用尼龙撬棒将顶部和底部的碟子盖在边缘处分开。
用手向上拉,只取下顶部的碟盖。
My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
使用 Phillips 00 螺丝刀从暴露的上部传感器面板上卸下三颗 12.8 毫米银色螺丝。
It’s Phillips 0, not 00.
You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
I had the same experience. Putting the screws back in made the bottom shell easier to remove.
I concur, you don’t need to remove these screws to take the bottom shell off.
I found mine had ph#000 screws size, not ph#00.
please do not remove the Phillips-head screws it is not necessary to remove them.
用手小心地拉开底部碟盘。
From what I can tell, there are two clicks on each side? one is quite easy, then the other one seems to require considerable force pushing down and on the side, I had to do it one side at a time and found two YouTube videos performing this step to use as reference. I have the vive pro wands and not the originals, so this may explain the difference. This felt very wrong to me.
翻转 Vive 手柄,使暴露的底托面板朝上。
使用 T5 Torx 螺丝刀卸下三颗黑色 5.2mm 螺丝。
Leave the middle screw where it is (the one being unscrewed in the picture). That screw holds the two halves of the photodiode assembly together, not the case.
five screws… two at bottom
I concur with trevosklar, don’t need to remove center screw to remove front panel (pad cover).
用两根手指将带状电缆向上拉离主板,轻轻断开上部带状电缆的连接。
You do not have to remove the ribbon cables from the plugs…you can carefully work the battery holder around them and remove it…being very gentle. And the black part of the handle will stay attached to the cables and be in the way. But removing the cables does make it easier to access the area for the battery, just not completely necessary.
使用尼龙撬棒将白色标签提起 90 度。
用两根手指向下拉带状电缆,轻轻断开底部带状电缆的连接。
Hallo what is the name of this conector because i Broker it
Yeah I did as instructed only to realize after that my gen 1 vive controller does not do that, and i desoldered the power button ribbon. That cable, does NOT detach on my model. destroyed.
要重新组装你的设备,请按逆序进行操作。
要重新组装你的设备,请按逆序进行操作。
11等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Where can I buy new t5 21 mm screws? Mine are getting stripped out!
jeremyvanwoerden - 回复
Where can you get replacement batteries?
Mike Justice - 回复
The middle bottom screw may have some form of warranty sticker on it if you have a Vive Pro wand (which is purple). Mine had this. Easy enough to remove and get on with it.
sodiboo - 回复
