跳转到主内容
HTC Trophy Display Assembly Replacement
你所需要的
  1. HTC Trophy Display Assembly Replacement, Battery: 步骤 1 中的图像 1,3 HTC Trophy Display Assembly Replacement, Battery: 步骤 1 中的图像 2,3 HTC Trophy Display Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
  2. HTC Trophy Display Assembly Replacement: 步骤 2 中的图像 1,3 HTC Trophy Display Assembly Replacement: 步骤 2 中的图像 2,3 HTC Trophy Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
  3. HTC Trophy Display Assembly Replacement, Display Assembly: 步骤 3 中的图像 1,3 HTC Trophy Display Assembly Replacement, Display Assembly: 步骤 3 中的图像 2,3 HTC Trophy Display Assembly Replacement, Display Assembly: 步骤 3 中的图像 3,3
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
  4. HTC Trophy Display Assembly Replacement: 步骤 4 中的图像 1,3 HTC Trophy Display Assembly Replacement: 步骤 4 中的图像 2,3 HTC Trophy Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
  5. HTC Trophy Display Assembly Replacement: 步骤 5 中的图像 1,3 HTC Trophy Display Assembly Replacement: 步骤 5 中的图像 2,3 HTC Trophy Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
  6. HTC Trophy Display Assembly Replacement: 步骤 6 中的图像 1,3 HTC Trophy Display Assembly Replacement: 步骤 6 中的图像 2,3 HTC Trophy Display Assembly Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
  7. HTC Trophy Display Assembly Replacement: 步骤 7 中的图像 1,2 HTC Trophy Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove power button from the top of the phone with tweezers.
  8. HTC Trophy Display Assembly Replacement: 步骤 8 中的图像 1,3 HTC Trophy Display Assembly Replacement: 步骤 8 中的图像 2,3 HTC Trophy Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 240
