跳转到主内容
加入维修社区 - 创建账户
HTC Touch Pro CDMA Verizon Keyboard Replacement
你所需要的
    1. HTC Touch Pro CDMA Verizon Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
      • Remove the back cover (not pictured) to your phone.
      询问修复机器人
      添加评论
    2. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 2 中的图像 1,2 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 2 中的图像 2,2
      • To remove the battery, place your thumb beneath the tab and begin to lift.
      • Pinching the battery, lift up at an angle from the bottom of the phone.
      询问修复机器人
      添加评论
    1. HTC Touch Pro CDMA Verizon Keyboard Replacement, Basic Parts: 步骤 3 中的图像 1,1
      • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
      • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
      询问修复机器人
      添加评论
    2. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 4 中的图像 1,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 4 中的图像 2,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 4 中的图像 3,3
      • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
      • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
      询问修复机器人
      添加评论
    3. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 5 中的图像 1,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 5 中的图像 2,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 5 中的图像 3,3
      • Next, remove the casing that covers the camera and motherboard.
      • To do this, place your thumbnail in any of the grooves along either side and pry it open.
      询问修复机器人
      添加评论
    4. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 6 中的图像 1,2 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 6 中的图像 2,2
      • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
      • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
      询问修复机器人
      添加评论
    5. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 7 中的图像 1,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 7 中的图像 2,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 7 中的图像 3,3
      • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
      询问修复机器人
      添加评论
    6. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 8 中的图像 1,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 8 中的图像 2,3 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 8 中的图像 3,3
      • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
      • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
      询问修复机器人
      添加评论
    1. HTC Touch Pro CDMA Verizon Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,1
      • Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
      • Using a PH 0 screwdriver, remove the 4 screws on the black slider.
      询问修复机器人
      添加评论
    2. HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 10 中的图像 1,2 HTC Touch Pro CDMA Verizon Keyboard Replacement: 步骤 10 中的图像 2,2
      • Pry the keyboard away from the screen. Open on the side containing the keyboard ribbon.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jack Bowen
于04/09/11注册
79 声望
创作了5篇指南
团队
Cal Poly, Team 20-67, Walters Spring 2011 Cal Poly, Team 20-67, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G67
4 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 32
总计 2,468
