简介
Building upon basic teardown guides, this guide will allow you to replace the camera inside your phone in about 20 minutes.
配件
没有特定配件。
Remove the back cover (not pictured) to your phone. Place it aside somewhere you won't lose it.
Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
The camera is only held in by one connection to the motherboard and some tape.
Remove its connection to motherboard in the same way that you've removed such connections in the past.
