当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
First, gently press on the back plate and push down toward the camera.
Use your finger to lift up the edge of the battery.
Remove the 4 screws using the T6 screw driver.
Lift the plastic cover near the memory card slot.
Remove the two Phillips #00 screws from the backside of the screen.
Insert a spudger or a plastic opening tool into the seam on the side of the phone.
Gently pry apart the two halves of the phone.
Gently unplug the connectors.
Remove the screws with a 00 Phillips-head screwdriver.
Gently lift the motherboard up using a nylon spudger.
BE AWARE OF THE ANTENNA.
取消:我没有完成这个指南。
与7其他贡献者
于04/28/11注册
133 声望
创作了4篇指南
徽章: 8
+ 5更多徽章
CSULA-NELSON-S11S1G6
3 名成员
创作了8篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,042
