本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a speaker that no longer outputs sound.
你所需要的
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
即将完成!
结论
