跳转到主内容
修复你的物品
维修的权力
商店
简介
Use this guide to replace a speaker that no longer outputs sound.
  1. Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. Lift and remove the rear panel.
    • Lift and remove the rear panel.
  3. Using the plastic opening tool, lift up the battery from the bottom near the kickstand. Remove the battery from the inner frame.
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. Remove the six Phillips screws from the perimeter of the rear frame.
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. Insert the plastic opening tool into the bottom of the phone underneath the soft keys. Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  7. Remove the two Phillips screws where the plastic cover was.
    • Remove the two Phillips screws where the plastic cover was.
  8. Insert the plastic opening tool in between the screen and the frame on the side of the phone. Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  9. Carefully separate the screen and phone from the rear frame, starting from the bottom. Gently pull down on the phone and screen to fully separate it from the rear frame. Gently pull down on the phone and screen to fully separate it from the rear frame.
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  10. Remove the two Phillips screws securing rear inner frame to device.
    • Remove the two Phillips screws securing rear inner frame to device.
  11. Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  12. Remove the rear inner frame from the rest of the device. Remove the rear inner frame from the rest of the device.
    • Remove the rear inner frame from the rest of the device.
  13. Flip over rear inner frame.
    • Flip over rear inner frame.
  14. Pry out speaker with plastic opening tools. You have now removed the speaker.
    • Pry out speaker with plastic opening tools.
    • You have now removed the speaker.
结论
Brandon Younger
于2013年01月17日注册
212 信誉积分
创作了8篇指南
团队
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G45
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 537
