跳转到主内容
HTC Thunderbolt Rear Frame Replacement
你所需要的
  1. HTC Thunderbolt Rear Frame Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Rear Frame Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Rear Frame Replacement, Battery: 步骤 3 中的图像 1,2 HTC Thunderbolt Rear Frame Replacement, Battery: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Rear Frame Replacement, MicroSD Card: 步骤 4 中的图像 1,2 HTC Thunderbolt Rear Frame Replacement, MicroSD Card: 步骤 4 中的图像 2,2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Rear Frame Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Rear Frame Replacement, Rear Frame: 步骤 6 中的图像 1,1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Rear Frame Replacement: 步骤 7 中的图像 1,2 HTC Thunderbolt Rear Frame Replacement: 步骤 7 中的图像 2,2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Rear Frame Replacement: 步骤 8 中的图像 1,1
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Rear Frame Replacement: 步骤 9 中的图像 1,2 HTC Thunderbolt Rear Frame Replacement: 步骤 9 中的图像 2,2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Rear Frame Replacement: 步骤 10 中的图像 1,3 HTC Thunderbolt Rear Frame Replacement: 步骤 10 中的图像 2,3 HTC Thunderbolt Rear Frame Replacement: 步骤 10 中的图像 3,3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G45
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 495
