跳转到主内容
加入维修社区 - 创建账户
HTC Thunderbolt Power Button Replacement
你所需要的
  1. HTC Thunderbolt Power Button Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
    询问修复机器人
    添加评论
  2. HTC Thunderbolt Power Button Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the rear panel.
    询问修复机器人
    添加评论
  3. HTC Thunderbolt Power Button Replacement, Battery: 步骤 3 中的图像 1,2 HTC Thunderbolt Power Button Replacement, Battery: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
    询问修复机器人
    添加评论
  4. HTC Thunderbolt Power Button Replacement, Rear Frame: 步骤 4 中的图像 1,1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
    询问修复机器人
    添加评论
  5. HTC Thunderbolt Power Button Replacement: 步骤 5 中的图像 1,2 HTC Thunderbolt Power Button Replacement: 步骤 5 中的图像 2,2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
    询问修复机器人
    添加评论
  6. HTC Thunderbolt Power Button Replacement: 步骤 6 中的图像 1,1
    • Remove the two Phillips screws where the plastic cover was.
    询问修复机器人
    添加评论
  7. HTC Thunderbolt Power Button Replacement: 步骤 7 中的图像 1,2 HTC Thunderbolt Power Button Replacement: 步骤 7 中的图像 2,2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
    询问修复机器人
    添加评论
  8. HTC Thunderbolt Power Button Replacement: 步骤 8 中的图像 1,3 HTC Thunderbolt Power Button Replacement: 步骤 8 中的图像 2,3 HTC Thunderbolt Power Button Replacement: 步骤 8 中的图像 3,3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
    询问修复机器人
    添加评论
  9. HTC Thunderbolt Power Button Replacement, Rear Inner Frame: 步骤 9 中的图像 1,1
    • Remove the two Phillips screws securing rear inner frame to device.
    询问修复机器人
    添加评论
  10. HTC Thunderbolt Power Button Replacement: 步骤 10 中的图像 1,1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
    询问修复机器人
    添加评论
  11. HTC Thunderbolt Power Button Replacement: 步骤 11 中的图像 1,2 HTC Thunderbolt Power Button Replacement: 步骤 11 中的图像 2,2
    • Remove the rear inner frame from the rest of the device.
    询问修复机器人
    添加评论
  12. HTC Thunderbolt Power Button Replacement, LCD/Screen: 步骤 12 中的图像 1,2 HTC Thunderbolt Power Button Replacement, LCD/Screen: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
    询问修复机器人
    添加评论
  13. HTC Thunderbolt Power Button Replacement: 步骤 13 中的图像 1,2 HTC Thunderbolt Power Button Replacement: 步骤 13 中的图像 2,2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
    询问修复机器人
    添加评论
  14. HTC Thunderbolt Power Button Replacement: 步骤 14 中的图像 1,1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
    询问修复机器人
    添加评论
  15. HTC Thunderbolt Power Button Replacement: 步骤 15 中的图像 1,2 HTC Thunderbolt Power Button Replacement: 步骤 15 中的图像 2,2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
    询问修复机器人
    添加评论
  16. HTC Thunderbolt Power Button Replacement, Power Button: 步骤 16 中的图像 1,3 HTC Thunderbolt Power Button Replacement, Power Button: 步骤 16 中的图像 2,3 HTC Thunderbolt Power Button Replacement, Power Button: 步骤 16 中的图像 3,3
    • Flip the LCD over so that it is facing downward.
    • Pry out the power button with a plastic opening tool.
    • You have now removed the power button.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G45
4 名成员
创作了36篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 35
总计 3,358
