跳转到主内容
  1. Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. Lift and remove the rear panel.
    • Lift and remove the rear panel.
  3. Using the plastic opening tool, lift up the battery from the bottom near the kickstand. Remove the battery from the inner frame.
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing. Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. Remove the six Phillips screws from the perimeter of the rear frame.
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. Apple Watch 套装
    Screen and battery repairs just got easier.
    现在开始购物
    Apple Watch 套装
    现在开始购物
  8. Insert the plastic opening tool into the bottom of the phone underneath the soft keys. Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  9. Remove the two Phillips screws where the plastic cover was.
    • Remove the two Phillips screws where the plastic cover was.
  10. Insert the plastic opening tool in between the screen and the frame on the side of the phone. Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  11. Carefully separate the screen and phone from the rear frame, starting from the bottom. Gently pull down on the phone and screen to fully separate it from the rear frame. Gently pull down on the phone and screen to fully separate it from the rear frame.
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  12. Remove the two Phillips screws securing rear inner frame to device.
    • Remove the two Phillips screws securing rear inner frame to device.
  13. Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  14. Remove the rear inner frame from the rest of the device. Remove the rear inner frame from the rest of the device.
    • Remove the rear inner frame from the rest of the device.
  15. Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable. Be careful opening these tabs as they are very easy to break.
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
  16. Lifting from the side where the ribbon was disconnected, flip over the motherboard. Remove the black tape covering the tabs connecting the motherboard and LCD.
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
  17. Using the plastic opening tool pop up  the two tabs connecting the LCD and motherboard.
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
  18. Once the tabs have been popped up, slowly pull the two pieces away from each other. If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
结论
11等其他人完成本指南。
Brandon Younger
于2013年01月17日注册
212 信誉积分
创作了8篇指南
团队
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G45
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 6,531
