跳转到主内容
HTC Surround Sim Card Replacement
你所需要的
  1. HTC Surround Sim Card Replacement, Back Case: 步骤 1 中的图像 1,2 HTC Surround Sim Card Replacement, Back Case: 步骤 1 中的图像 2,2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround Sim Card Replacement: 步骤 2 中的图像 1,3 HTC Surround Sim Card Replacement: 步骤 2 中的图像 2,3 HTC Surround Sim Card Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround Sim Card Replacement: 步骤 3 中的图像 1,1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround Sim Card Replacement, SD Card: 步骤 4 中的图像 1,3 HTC Surround Sim Card Replacement, SD Card: 步骤 4 中的图像 2,3 HTC Surround Sim Card Replacement, SD Card: 步骤 4 中的图像 3,3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround Sim Card Replacement: 步骤 5 中的图像 1,2 HTC Surround Sim Card Replacement: 步骤 5 中的图像 2,2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  6. HTC Surround Sim Card Replacement, Sim Card: 步骤 6 中的图像 1,1
    • The SIM card slot will come off the device with the SD card slot and is ready to replace.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 17
总计 324
