跳转到主内容
HTC SMT 6175 Motherboard Replacement
你所需要的
  1. HTC SMT 6175 Motherboard Replacement, Back Case: 步骤 1 中的图像 1,1
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Motherboard Replacement: 步骤 2 中的图像 1,2 HTC SMT 6175 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 HTC SMT 6175 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Motherboard Replacement, Interior Back Case: 步骤 4 中的图像 1,2 HTC SMT 6175 Motherboard Replacement, Interior Back Case: 步骤 4 中的图像 2,2
    • To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
  5. HTC SMT 6175 Motherboard Replacement: 步骤 5 中的图像 1,2 HTC SMT 6175 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull off the case.
    • This can be difficult. Just start pulling the back out from the front shell and, as it starts to lift up, continue moving around the phone until the whole back becomes free.
  6. HTC SMT 6175 Motherboard Replacement, Taking out the Motherboard: 步骤 6 中的图像 1,1
    • Next, unscrew the top screw using a small, Philips screwdriver.
    • Pull back the motherboard.
    • The LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable and to the front case by an adhesive.
  7. HTC SMT 6175 Motherboard Replacement, Taking out the Display Screen: 步骤 7 中的图像 1,2 HTC SMT 6175 Motherboard Replacement, Taking out the Display Screen: 步骤 7 中的图像 2,2
    • Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
    • The LCD is attached with a sticky adhesive so it might be difficult to get off.
  8. HTC SMT 6175 Motherboard Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Place the motherboard down on top of the LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
  9. HTC SMT 6175 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
    • The sticky gray tape might have to be ripped in order to be removed because of its extreme stickiness.
结论
另外一个人完成了本指南。
Jordan
于04/12/11注册
31 声望
撰写一个指南
团队
Cal Poly, Team 25-29, Garner Spring 2011 Cal Poly, Team 25-29, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G29
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,744
