简介
Follow the steps below to replace the motherboard of your HTC SMT 6175 phone.
你所需要的
Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver.
Pull back the motherboard.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
另外一个人完成了本指南。
