跳转到主内容
简介
Hello! This should be followed if your phone is having issues with the vibration function. Please be sure to follow the steps in the screen replacement guide up to the indicated point! Have fun fixing your tech!
  1. Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is  visible.
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
  2. Remove the red battery to replace.
    • Remove the red battery to replace.
  3. Using a Torx T4 screwdriver, remove the six screws from the  six spots shown in the photo. Use a spudger to pry the casing from the phone. Use a spudger to pry the casing from the phone.
    • Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
    • Use a spudger to pry the casing from the phone.
  4. Gently remove casing from phone. Gently remove casing from phone.
    • Gently remove casing from phone.
  5. Shown here is the vibration Monitor, this is what you will be replacing.
    • Shown here is the vibration Monitor, this is what you will be replacing.
  6. Remove the body of the monitor from the case attaching it to the motherboard. Make sure to remove any potential obstruction that could be blocking the weight at the end! Make sure to remove any potential obstruction that could be blocking the weight at the end!
    • Remove the body of the monitor from the case attaching it to the motherboard.
    • Make sure to remove any potential obstruction that could be blocking the weight at the end!
  7. Carefully disconnect the cable attached at the motherboard.
    • Carefully disconnect the cable attached at the motherboard.
  8. Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
    • Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
结论
Robin White
于2018年01月29日注册
133 信誉积分
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 70
