跳转到主内容
加入维修社区 - 创建账户
HTC Rezound Screen Replacement
你所需要的
  1. HTC Rezound Screen  Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
  2. HTC Rezound Screen  Replacement: 步骤 2 中的图像 1,1
    • Remove the red battery to replace.
  3. HTC Rezound Screen  Replacement, Screen: 步骤 3 中的图像 1,3 HTC Rezound Screen  Replacement, Screen: 步骤 3 中的图像 2,3 HTC Rezound Screen  Replacement, Screen: 步骤 3 中的图像 3,3
    • Unscrew the six screws (Torx T4 size) shown in the photo.
    • Use the spudger to pry the casing off of the phone.
  4. HTC Rezound Screen  Replacement: 步骤 4 中的图像 1,2 HTC Rezound Screen  Replacement: 步骤 4 中的图像 2,2
    • Gently remove the casing from the phone.
  5. HTC Rezound Screen  Replacement: 步骤 5 中的图像 1,1
    • After the red casing is removed, the following components should be visible:
    • Main Camera
    • Headphone Jack
    • Vibration moter
  6. HTC Rezound Screen  Replacement: 步骤 6 中的图像 1,2 HTC Rezound Screen  Replacement: 步骤 6 中的图像 2,2
    • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
  7. HTC Rezound Screen  Replacement: 步骤 7 中的图像 1,3 HTC Rezound Screen  Replacement: 步骤 7 中的图像 2,3 HTC Rezound Screen  Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
    • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
结论
Bridgette Mellon
于01/29/18注册
243 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 358
