跳转到主内容
加入维修社区 - 创建账户
HTC Radar 4G Casing Replacement
你所需要的
  1. HTC Radar 4G Casing Replacement, Slide off the back panel: 步骤 1 中的图像 1,2 HTC Radar 4G Casing Replacement, Slide off the back panel: 步骤 1 中的图像 2,2
    • Slide off the white back panel.
    • This is the time to remove the SIM card, so remove it now.
  2. HTC Radar 4G Casing Replacement, Remove the motherboard protector screws: 步骤 2 中的图像 1,1
    • Remove the 4 silver T5 Torx screws from the motherboard protector.
    • Some screws may be stuck in. If so, use a pair of tweezers to carefully remove them from their holes.
  3. HTC Radar 4G Casing Replacement, Slide off the rear motherboard protector: 步骤 3 中的图像 1,1
    • Carefully slide off the motherboard protector.
    • This may take some force if this is the first time opening the phone.
    • Take care not to apply too much downward force, because you may accidentally damage the sensitive components on the motherboard.
  4. HTC Radar 4G Casing Replacement, Remove the frame screws: 步骤 4 中的图像 1,1
    • Remove the 2 black T5 Torx screws from the silver frame.
    • Make sure to not accidentally slip the screwdriver, because you may break sensitive components on the motherboard.
  5. HTC Radar 4G Casing Replacement, Remove the casing: 步骤 5 中的图像 1,1
    • Gently push on the motherboard until the display starts to come out of its frame.
    • Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
    • Remember, do this carefully. We don't want to end up with a dead motherboard.
结论
另外一个人完成了本指南。
hellonearth311
于03/30/24注册
390 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 136
