跳转到主内容
HTC Ozone Motherboard Replacement
你所需要的
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: 步骤 1 中的图像 1,1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: 步骤 2 中的图像 1,2 HTC Ozone Motherboard Replacement: 步骤 2 中的图像 2,2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: 步骤 3 中的图像 1,3 HTC Ozone Motherboard Replacement, Battery: 步骤 3 中的图像 2,3 HTC Ozone Motherboard Replacement, Battery: 步骤 3 中的图像 3,3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: 步骤 4 中的图像 1,3 HTC Ozone Motherboard Replacement, Frame: 步骤 4 中的图像 2,3 HTC Ozone Motherboard Replacement, Frame: 步骤 4 中的图像 3,3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: 步骤 5 中的图像 1,3 HTC Ozone Motherboard Replacement: 步骤 5 中的图像 2,3 HTC Ozone Motherboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 HTC Ozone Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: 步骤 7 中的图像 1,2 HTC Ozone Motherboard Replacement: 步骤 7 中的图像 2,2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: 步骤 8 中的图像 1,3 HTC Ozone Motherboard Replacement: 步骤 8 中的图像 2,3 HTC Ozone Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
结论
另外一个人完成了本指南。
Marco Jokada
于04/28/11注册
247 声望
创作了6篇指南
团队
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G2
5 名成员
创作了12篇指南
一条评论
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 1,542
