跳转到主内容
HTC Ozone Keyboard Replacement
你所需要的
  1. HTC Ozone Keyboard Replacement, Rear Battery Cover: 步骤 1 中的图像 1,1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Keyboard Replacement: 步骤 2 中的图像 1,2 HTC Ozone Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Keyboard Replacement, Battery: 步骤 3 中的图像 1,3 HTC Ozone Keyboard Replacement, Battery: 步骤 3 中的图像 2,3 HTC Ozone Keyboard Replacement, Battery: 步骤 3 中的图像 3,3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Keyboard Replacement, Frame: 步骤 4 中的图像 1,2 HTC Ozone Keyboard Replacement, Frame: 步骤 4 中的图像 2,2
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Keyboard Replacement: 步骤 5 中的图像 1,3 HTC Ozone Keyboard Replacement: 步骤 5 中的图像 2,3 HTC Ozone Keyboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Keyboard Replacement, Motherboard: 步骤 6 中的图像 1,2 HTC Ozone Keyboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Keyboard Replacement: 步骤 7 中的图像 1,2 HTC Ozone Keyboard Replacement: 步骤 7 中的图像 2,2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Keyboard Replacement: 步骤 8 中的图像 1,3 HTC Ozone Keyboard Replacement: 步骤 8 中的图像 2,3 HTC Ozone Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone Keyboard Replacement, LCD Display: 步骤 9 中的图像 1,2 HTC Ozone Keyboard Replacement, LCD Display: 步骤 9 中的图像 2,2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone Keyboard Replacement: 步骤 11 中的图像 1,2 HTC Ozone Keyboard Replacement: 步骤 11 中的图像 2,2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone Keyboard Replacement: 步骤 12 中的图像 1,1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone Keyboard Replacement: 步骤 13 中的图像 1,1
    • Lift the Motherboard away from the LCD display.
  14. HTC Ozone Keyboard Replacement, Keyboard: 步骤 14 中的图像 1,2 HTC Ozone Keyboard Replacement, Keyboard: 步骤 14 中的图像 2,2
    • Lift off main keyboard from front plastic case using plastic opening tool.
  15. HTC Ozone Keyboard Replacement: 步骤 15 中的图像 1,2 HTC Ozone Keyboard Replacement: 步骤 15 中的图像 2,2
    • Remove four Phillips #00 screws securing function keys.
  16. HTC Ozone Keyboard Replacement: 步骤 16 中的图像 1,2 HTC Ozone Keyboard Replacement: 步骤 16 中的图像 2,2
    • Pop keys out by pushing keys from back of the phone.
结论
另外一个人完成了本指南。
Marco Jokada
于04/28/11注册
247 声望
创作了6篇指南
团队
CSU Los Angeles, Team 1-2, Nelson Spring 2011 CSU Los Angeles, Team 1-2, Nelson Spring 2011 的会员
CSULA-NELSON-S11S1G2
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,882
