跳转到主内容
HTC One X Plus Top Speaker Replacement
你所需要的
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: 步骤 1 中的图像 1,1
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: 步骤 2 中的图像 1,3 HTC One X Plus Top Speaker Replacement: 步骤 2 中的图像 2,3 HTC One X Plus Top Speaker Replacement: 步骤 2 中的图像 3,3
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: 步骤 3 中的图像 1,3 HTC One X Plus Top Speaker Replacement: 步骤 3 中的图像 2,3 HTC One X Plus Top Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: 步骤 4 中的图像 1,3 HTC One X Plus Top Speaker Replacement: 步骤 4 中的图像 2,3 HTC One X Plus Top Speaker Replacement: 步骤 4 中的图像 3,3
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: 步骤 5 中的图像 1,2 HTC One X Plus Top Speaker Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: 步骤 6 中的图像 1,3 HTC One X Plus Top Speaker Replacement: 步骤 6 中的图像 2,3 HTC One X Plus Top Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: 步骤 7 中的图像 1,2 HTC One X Plus Top Speaker Replacement: 步骤 7 中的图像 2,2
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
结论
另外一个人完成了本指南。
Jason Melo
于08/26/15注册
483 声望
创作了4篇指南
团队
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S3G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 432
