跳转到主内容
HTC One X Plus Motherboard Replacement
你所需要的
  1. HTC One X Plus Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: 步骤 2 中的图像 1,3 HTC One X Plus Motherboard Replacement: 步骤 2 中的图像 2,3 HTC One X Plus Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: 步骤 3 中的图像 1,3 HTC One X Plus Motherboard Replacement: 步骤 3 中的图像 2,3 HTC One X Plus Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: 步骤 4 中的图像 1,3 HTC One X Plus Motherboard Replacement: 步骤 4 中的图像 2,3 HTC One X Plus Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: 步骤 5 中的图像 1,2 HTC One X Plus Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: 步骤 6 中的图像 1,3 HTC One X Plus Motherboard Replacement: 步骤 6 中的图像 2,3 HTC One X Plus Motherboard Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
结论
另外一个人完成了本指南。
Jason Melo
于08/26/15注册
483 声望
创作了4篇指南
团队
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S3G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 1,244
