跳转到主内容
HTC One X Battery Replacement
你所需要的
视频概述
  1. HTC One X Battery Replacement, Battery: 步骤 1 中的图像 1,3 HTC One X Battery Replacement, Battery: 步骤 1 中的图像 2,3 HTC One X Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Switch the phone off.
    • Remove the SIM tray.
    • The back cover is stuck to the phone with adhesive tape.
    • It's helpful to use heat to loosen the adhesive, making removal much easier.
  2. HTC One X Battery Replacement: 步骤 2 中的图像 1,3 HTC One X Battery Replacement: 步骤 2 中的图像 2,3 HTC One X Battery Replacement: 步骤 2 中的图像 3,3
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X Battery Replacement: 步骤 3 中的图像 1,2 HTC One X Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the display assembly from the body of the phone.
  4. HTC One X Battery Replacement: 步骤 4 中的图像 1,2 HTC One X Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the seven Philips #0 screws at the top of the panel:
    • Two 2.05 mm screws
    • Three 2.44 mm screws
    • Two 3.35 mm screws
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  5. HTC One X Battery Replacement: 步骤 5 中的图像 1,3 HTC One X Battery Replacement: 步骤 5 中的图像 2,3 HTC One X Battery Replacement: 步骤 5 中的图像 3,3
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  6. HTC One X Battery Replacement: 步骤 6 中的图像 1,2 HTC One X Battery Replacement: 步骤 6 中的图像 2,2
    • A piece of copper tape covers the battery and an EMI shield on the motherboard.
    • Carefully pry the EMI shield up at the top of the phone and toward the battery.
    • Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
  7. HTC One X Battery Replacement: 步骤 7 中的图像 1,3 HTC One X Battery Replacement: 步骤 7 中的图像 2,3 HTC One X Battery Replacement: 步骤 7 中的图像 3,3
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery and you are ready to install the new one.
  8. HTC One X Battery Replacement: 步骤 8 中的图像 1,2 HTC One X Battery Replacement: 步骤 8 中的图像 2,2
结论
13等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
2条评论
Perfecto! Me vino genial el tutorial y es perfecto, mejor que otros.
hepugh - 回复
Went very well. I had a dead HTC One X that I replaced 4 years ago. I came across it a few weeks ago and thought to give a new battery a try, to see if I can get the photos off it. It did not charge (no lights) and did not turn on anymore. I ordered a battery from AliExpress and it came in today. Followed this guide, and yes, it turned on again! And charging is also working properly now. So I am happy, now I can get my photos and use the phone as a Android 4.2 testing target for the apps I develop. Wonderful.
Peterdk - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 35
总计 46,519
