当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
加热iOpener三十秒
在整个维修过程中,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
如果iOpener过热膨胀,千万不要触碰iOpener。
如果iOpener中间部分依然烫的没法碰,请等待冷却后再使用,加热好的iOpener 应该可以保持热度十分钟
如果你没有微波炉,请按照此步骤在沸水中加热iOpener。
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
iOpener会很燙,所以拿取時請小心的從iOpener的邊邊拿
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
Handling it by the tag, place the heated iOpener across the bottom casing.
Let the iOpener sit for at least a minute to soften the adhesive beneath the casing.
Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Place your fingers on either side of the phone and gently push up on the rear case.
It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there.
Use the pointed edge of a spudger to work the ZIF cable out of its connector.
To do this, you may have to slowly work both sides until the whole cable is released.
Remove the plastic casing from the phone assembly.
If you are having difficulty removing the casing, use a plastic opening tool to gently pry it from the phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
